Paul in Beaufort
I have read whatever I can find relating to my car's problems and tried suggested remedies without much improvement. By the way, this is my first diesel.
My '03 Jetta tdi started hesitating - or maybe more accurately stumbling -on acceleration and it lacked power. I replaced the MAF with no improvement. I took it to a shop and they replaced the fuel filter (because of some apparently bad fuel) which got rid of the "hitches" but the power wasn't what it should be. I have a Foxwell scanner (which I bought to set the fuel deliver amount after replacing the injection pump cover seal) and the only code was an intermittent issue with the EGR system.
I removed the EGR valve and found it was stuck closed. A good cleaning got it moving again and the code has not returned. But power is still below what it should be.
Somewhere in all this the car had started pouring out black smoke - which appears to be from overfueling. I can't say exactly when because I didn't realize it was happening because it wasn't noticeable in the mirror for a while. The black spot on the ground under the tailpipe caused me to start paying attention.
Next, I replaced all the vacuum lines. No improvement. Then I looked at the vacuum check valve (between N18 & reservoir) and it was working as it should. When I put it back in the car though I put it in backwards and, curiously to me, the black clouds were gone but so was the boost. I put it in correctly and the boost returned... and so did the smoke.
It might help to know that I replaced the turbo and cleaned the intake manifold less than 10k miles ago and it ran well until recently.
Unfortunately I don't have enough experience to know what the Foxwell scanner readings mean. I know the MAF specified and actual numbers improved with the clean EGR and the specified and actual boost approximate one another. But I don't know what the N75 & 18 solenoid readings should be telling me or what other readings I should be looking at.
I'd appreciate any wisdom or suggestions anyone is inclined to share.
Thanks.
Paul
Thanks.
Paul
