highmileage
- Joined
- Sep 17, 2013
- Location
- new jersey
- TDI
- 2005 passat bhw tdi (presently), 2001 jetta alh tdi (previously), 1998 jetta ahu tdi (previously)
If through the course of events camshaft and crankshaft move independently and end up out of sync, one way to restlore is to put cam qnd crank sprocket at tdc with timing tools in place to verify and hold tdc. The belt can then be installed with tools in place. Remove tools rotate 2 times with no problem and then reinsert tools. They fit at DTC. Rotate engine 2/more times for good measure. Always good to go? Any exceptions? Is smooth rotation of engine by crank bolt always an indication to safe start? Thanks in advance.
