I have a 99.5 that dropped a valve at 180k, so would like to rob the larger injectors and the tune for my new project, a 2003 ALH. I know the wiring is different but is there any hope in a chip swap or swap software side?
The ECU is going to be generally incompatible with the rest of the car. Different number of pins, and I don't think the CAN even runs at the same speed.
