SoCATDI
- Joined
- May 18, 2009
- Location
- CA for 36 yrs-now in TX
- TDI
- 2005 Passat TDI GLS Wagon, 2003 Golf TDI, 1998 Jetta TDI sadly totaled by teen driver, 2014 Jetta SportWagen TDI
Hello again! I replaced the crankshaft sensor 6 months +- ago. All was well and I started to enjoy the car again. Alas, yesterday the problem came back. The engine will stall at any speed. I coast to a stop, the engine will crank,but not start and the rpm gauge registers 0. Then the engine will start, rpm gauge reads the engine rpm as it should, the engine will then run for 1 minute or maybe 3 minutes. But it will not run for very long. It then stalls and repeats itself. I immediately thought perhaps a rat had eaten a wire or something. I can find no evidence of a "rat under the hood"! Can any one suggest what should be my next step. I almost forgot, the code thrown is PO321 Ignition/Distributor Engine Speed Input Circuit Range/Performance. This is an ALH engine.
SoCATDI now in Texas.
2003 golf - 380,000+ miles
2005 passat - 200,00+miles
1996 ford f350- 150000+miles
