After a long hiatus, its time to invest some time into my parked Golf...
The car seems to run well when its warm. It starts easily and has seemingly good power. The car misfires and smokes at every cold startup, eventually clears up. Smoke is greyish and smells of unburned diesel. It will occasionally throw a cylinder #3 Misfire code. I swapped injectors and have checked a few other things. At the point I was pretty sure there was a mechanical problem i bought a cheap compression tester that turned out to be complete garbage. I have a higher quality one now that I trust. Numbers: (taken slightly warm, not at temp)
#1 - 485psi
#2 - 440psi
#3 - 410psi
#4 - 480psi
I have no history on this car. I suspect the car may have a partially bent #2/3 conrod from an "incident" of some sort? I also suspect that the previous owner possibly drove said car "awhile" like this. What are the chances the block may have scored up cylinder walls? If i pull oil pan, with these numbers any chance i could see a bent rod and/or check cyl wall. I realize this will likely end with pulling head off! If bent rods only, I'd like to fix with engine in car.
Chance of valve issues possible? Head is gunky looking on intake side. IF a rod(s) are bent I would be very interested in using Franko6's services for reassembly and parts. Another thought was installing a set of used rods and pistons and measuring for proper head gasket.
Your opinions and/or experiences greatly appreciated!
#1 - 485psi
#2 - 440psi
#3 - 410psi
#4 - 480psi
